fuel gage problem
				Kalto
- Vehicle: Mitsubishi delica l300
fuel gage problem
so i got a problem on the fuel gage, at 2wd its not working but the empty light yes and on the 4wd its all working do you know where it could be my probleme on the wiring systeme??
fuel gage problem
The fuel sender shares its earth connection with the 4wd switch, I think that's where you should look first. The wires should connect down near the rear tank.
				Kalto
fuel gage problem
it could be  a bad earth?
fuel gage problem
It almost has to be, that's the only point where the two systems are connected.
				Kalto
fuel gage problem
good thqnks ill check that tomorrow
