Hello all,
I am finishing up a Delica for a customer and I ran into a bit of a snag yesterday while finishing up the R134a conversion. After I charged the system, I started the truck only to find no compressor or condensor fans working. I checked all of the fuses behind the glove box and discovered that no power was going into the White/red 15A fuse on the far right of the cooling box. This led me to a two hour google search and wiring schematic pour over until finally ending up back here to double check the L300 service manual. Low and behold, there is a fusible link near the battery JUST for a/c components. It's a white fusible link and the harness connector is to the left of the battery. That was loose. So I hope this saves someone some trouble.
K
No Compressor Condensor Fan Operation
Killbert
- Vehicle: 91 Delica Chamonix
Trinker
- Vehicle: L300
Wicked!!!!! I haven't had AC for more than a year, checked all the fuses and the thermo coupler a while ago when that didn't work half gave up. Read this in the am, checked and sure enough the clip that holds the link together by the battery broke and the cables came apart! Plugged it back in and my system cane back instantly! Hot damn it's going to be a good summer
92'L300 Chamonix - Fully camperized adventure rig
Killbert
SweeeeeetTrinker wrote:Wicked!!!!! I haven't had AC for more than a year, checked all the fuses and the thermo coupler a while ago when that didn't work half gave up. Read this in the am, checked and sure enough the clip that holds the link together by the battery broke and the cables came apart! Plugged it back in and my system cane back instantly! Hot damn it's going to be a good summer
Sent from my SAMSUNG-SM-G891A using Tapatalk
