Do any of you have insights into the wiring of the flood/fog lights. I have 2 plugs with 3 wires in each. But the Bosche lights on my van only have 2 wires (power & ground).
Were the stock flood/fogs a high/low beam?
Bosch fog/flood's need properly wired
Zebruken
- Vehicle: n/a
Morgonzo
- Vehicle: L300
what year l300? On my 88 the fogs are not Hi/Lo switchable, but is only an Exceed. I don't know if that was an option on the Super and Royal trim levels but I doubt it. It'd be cool though
I've never had my fog's apart but it looks like a one bulb/one clip affair. My fog's are labeled MM400 Magnum if that helps.
The "Zanimo Wagon" 1988 Mitsu Delica L300 StarWagon P25W 5spd
"Zowie Zow!"
"Zowie Zow!"
Overlanderjay
- Vehicle: Ford E350 Econodeli powerveg
Are you sure your dealing with stock Mitsubishi wiring or aftermarket wiring Delis never came with high/low foglights Cheers Jay
"Electrickery Technition"
