harmonic balancer removal tool needed
Temporary tool loans or swaps
thelazygreenfox
Post by thelazygreenfox »
Hey everyone
I need a harmonic balancer removal tool for my L400. I'm changing the timing belt and water pump and need to pull the harmonic balancer first. I'll make one if I can't borrow one from someone in the Greater Vancouver area.
thanks
Wayne
It looks like this.
thelazygreenfox
Another delica owner just reminded me of how to break the HB nut free . I had forgotten freeing it this way years ago. Easy peasy..
With the 22mm socket on the nut place an extension on the ratchet bar so the ends rests securely on the floor under the van. Disconnect the plug leads so the engine won't start and hit the key quickly. The starter action will break the nut free for you.
problem solved. Thanks Laurent
MD :-D :-D
Return to “Tool Swaps, Share, Trade”
