91 Delica L300 Exceed.
I have the dual battery system in my Delica and am thinking of changing to Odyssey batteries.
I see some people are using group 34 and some are using group 35. Seems like they would both fit but which is preferred, if any?
Thanks.
Battery Size
- tomaboyd
- Vehicle: 1991 Delica Exceed
GrinMedic
- Vehicle: 1991 L300 Super Exceed
Battery Size
I replaced my dying/dead dual batteries in my 91' Super Exceed with a single Odyssey PC1500 DT. Group 34/78.
I used the existing securement bar and hook bolt, but put a larger sized nut as a washer as the threads weren't long enough.
I cut down/ modified the dual battery leads and it worked a charm. Fired up instantly in -4 C this morning on a single glowplug cycle, seems way more powerful than the previous ones.
I need to clean up the accessory wiring and think about using one or both of the side terminals, but it held as solid as could be while driving all day today on potholed roads and city.
Expensive, but should last a long long time of excellent use. Plus it frees up a whole bunch of space in the battery compartment for fuse blocks and the like!
Killbert
- Vehicle: 91 Delica Chamonix
Battery Size
I installed dual 34 AGM batteries recently. Phenomenal difference.
K
K
- LDiz
- Vehicle: 91 GLX Pop Top
Battery Size
Yep. Fit two of these. Tight Tight Tight:
Odyssey Extreme 34M-PC1500ST
