lets play... name that van part!
lookoutworld
Vehicle: 1990 P25W - 5 speed
Post by lookoutworld »
Hi guys and gals!
So, I found this under my rear bumper. Any idea what it could be? There are wires coming out of it. One end seems to be slightly rubbery (as opposed to plastic-y or metal-y). Could it be a "reverse beep noise speaker!?! A car alarm?! I'll post more pictures of random gizmos I've found in my van too. Maybe they are related.
Thanks everyone!
-Scott
motorang
Vehicle: L300 P25W
Re: lets play... name that van part!
Post by motorang »
Hi Scott,
that looks like a little air compressor for an air horn. No hose connector there? Maybe once upon a time it was for a diff lock or a kind of pump-up shockies.
What happens if you unplug the cables and power them (red to battery positive, black to battery negative)?
It may as well be a kind of siren or air horn, but usually it would be open to one side then.
It is NOT original thats sure ;-)
Andy
ChuckBlack
Vehicle: L300 Jasper
Post by ChuckBlack »
Jump it! Whatever it is!!! A time capsule?
L300 Jasper, :-D
L300 Chamonix, :-)
Pajero Mini, :-(
Pajero GDI :o
Pajero DiD 8-)
lookoutworld
(EDIT: fixed image links)
(EDIT AGAIN: changed to attachments)
More gizmos! Any ideas?
Second Gizmo (close up):
File Aug 27, 5 21 09 PM.jpeg (438.17 KiB) Viewed 9411 times
Notice that it has a "min" and "max" adjustable screw.
Second Gizmo (farther away):
File Aug 27, 5 21 25 PM.jpeg (586.7 KiB) Viewed 9411 times
third gizmo:
The attachment File Aug 27, 5 21 49 PM.jpeg is no longer available
File Aug 27, 5 21 49 PM.jpeg (551.08 KiB) Viewed 9411 times
Something funky has happened to your Google image links.
lookoutworld
links fixed! (hopefully)... my old Picasa workflow was recently trashed... thanks google.
The thing in your steering column is an impact/shock sensor for an alarm. The thing on the windscreen is a mystery: some kind of transponder, at a guess.
Pajero
Vehicle: 94 Pajero
Post by Pajero »
Looks like a two way alarm system to me that has a sensitivity adjustment. Not sure about the thing in the back as it does not look like a typical siren.
Overlanderjay
Vehicle: Ford E350 Econodeli powerveg
Post by Overlanderjay »
Backup alarm with possiblily a Japanese voice warning you that the van is backing up.car alarm shock sensor on the steering column ,antenna for the car alarm on the windshield .follow the wires there is probaly going to be a control box for the alarm system .
"Electrickery Technition"
lookoutworld
MORE gizmos!!!!
perhaps my van had some "hella" lights at some point? perhaps this is some little controller?:
hella smaller.jpeg (564.75 KiB) Viewed 9346 times
And the big mystery... a stealth button!
button smaller.jpeg (606.67 KiB) Viewed 9346 times
oh these vans... :?
Overlanderjay
Relay for lights ,"valet"control button for car alarm This is to easy lets have some tougher ones
ChuckBlack
Holy Capitanos! You've got some rust inside the dash! Weird...unless you were in some deep water... I'd say you've got a back to the future switch there!!!
L300 Jasper, :-D
L300 Chamonix, :-)
Pajero Mini, :-(
Pajero GDI :o
Pajero DiD 8-)
