EGR blanking plates for the L300 or L400.
Recommend 0.25 inch steel plate. You can fabricate these yourselves quite cheaply by heading down to the metal supermarket and buying some mild plate steel, hardened steel not necessary. Use an angle grinder and some drills. Print the PDF of your choice, either metric or imperial. Remember to set the "Page scaling" to "NONE" in Adobe Acrobat. Un-click the checkbox "Choose paper source by PDF page size".
Check the scale by measuring the square in the upper left corner with your calipers. Cut out the template with scissors and spray glue it onto the steel plate. Mark the outline and holes with a sharpee pen. Cut out the shapes then install. I sealed mine with high heat silicone and OE gaskets. Good luck.
