Headlight Issues
islander20
- Vehicle: 1994 L400 LWB
Headlight Issues
I just recently noticed that one of my headlights is out. When I have my lights set to low beams one of the headlights is out, but if I set them to hi beams both lights are on. I also noticed the both of the inner bulbs in the smaller reflector are out. When are these supposed to be one? Hi/Lo beams? Thanks, I'm not sure if this is electrical or something else.
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Re: Headlight Issues
The outer reflectors are your low beam and high beam (2 filaments in one bulb) The inner reflectors are your high beams as well so all 4 should be lit when high beam is on.
One of your outer bulbs has a broken low beam filament....time to replace it but the hi/lo bulbs should be changed in pairs when one burns out.
Good time to look at whiter/brighter bulbs.
