Hey folks,
So im having a issue with my l300 with the 4d56. ill give you a little back story before i dive right in. I have owned this van for a little over 2 years. I bought it with 108000km and i am currently just a touch over 150000km so i i have put on about 42000km since i have owned it. I have never had any problems with the van since i have owned it. the only work i have done is the basic stuff like oil change, glow plugs etc. I also changed the timing belt about a year ago when my other belt went.
The problem happened today. My van was parked at my acreage and with the recent rain it was a touch muddy. I couldnt get out in 2wd so I put it in 4wd. I engaged and i crawled out with no issues and then put it back into 2wd (I should note that i probly haven't used 4wd in more then 6 months) and continued on. once i got on the highway and tried getting it to speed I could tell something was wrong. I lost most all my power once i hit 80km/h. The power was cutting in and out in and out and then i could here some grinding noise. once i pulled over and lift the seat up there was a little bit of smoke coming up from right where the upper rad hose connects to the block. couldnt tell if it was the hose itself or was coming from below. I tried re engaging and disengaging the 4wd again to see if that helped but no luck. It seems to only make the grinding noise when im on the throttle. A "mechanic" ( at least thats what he told me) pulled over and told me he things its the timing tension-er or something but im not convinced. Im no diesel mechanic so I really am not to sure what im dealing with.
let me know if you need more info
any suggestions would be awesome
Travis
PS. I just moved to Edmonton, Ab and could really use the name of a good shop for the delica as well.
Grinding noise + smoke
rouxel
- Vehicle: Mitsubishi Pajero
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
