I want to installed a new floor in my van and I have a bounch of lamite floor in my garage. My question is, is it a good sound barrier??? For all road noise while driving. I'm thinking to keep the factory isolation pad underneed. Is it a good Plan??
Everything is already out. I'll clean it tonight and start the floor tomorow.
thank you!!
Laminate Floor...
P.Gaudreault
- Vehicle: Mitsubishi Delica 1998 Chamonix
- Nordo
- Vehicle: 93 Exceed
Re: Laminate Floor...
I put Laminate in my van and love it!! Hard to say if it is better for sound or not, in my opinion it would only be a few decibels if any difference. I have an L300 and from my experience they are not the quietest ride in the world to begin with, but that being said, I left the foam on the bottom of the laminate that I installed and just used PL400 to glue down the boards. I would think that if you removed the factory pads you would get vibration from the wood directly on the metal floor of the van and that would probably increase noise for sure! If you really wanted to decrease noise you could always buy acoustic isolation matt from an audio dealer and put that down first then the floor, but that would add 150 lbs or more of weight.
Here is a link to what I did to my van http://www.delica.ca/forum/viewtopic.php?f=10&t=14916
P.Gaudreault
Thank you Nordo.
It is went I saw your post that I decided to installed laminate floor in my Van. My old smell like shit and needs to be replace. I have a L400 and it is not the quitest ride on earth for sure.
But I don't want to increase the noise. I'll see tomorow how it goes and I'll decide from there I think. Small bench project after that and I'm think to built a roof rack like your's. He his awesome, but I want to built it with metal tubebing and I have an Idea for inproving the mount in the guter. Is it the same guter on the L400 than L300??
P.Gaudreault
Floor installed!!!!! Finaly I decided to trough the factory isolation away. I glue with PL every piece on the metal floor and use gap filler for isolate the empty space. I road test this morning and my van is quieter than before. There is some littel spot to fill and small pieces to manufacrue and all will be done.. Picture will come.
Sorry for my 4 years old boy english.. But the more important is that you can understand.
