IP location
punkrawker
Vehicle: L300
IP location
Post by punkrawker »
I am curious as to where the IP is located on a 91 l300 2.5td 5spd. any info, links to existing forums much appreciated.
Re: IP location
The Injector Pump? It's the big metal thing at the end of all the injector tubes, between the rocker cover and the battery compartment if you're looking at the engine. The thing that has the accelerator cable (and all the linkages) attached to it. If it was missing, you'd be able to see the aircon pump from above.
Here's a picture of an engine with the IP in place,
the same engine without the IP,
and what the IP looks like on the bench. After being cleaned.
punkrawker
Vehicle: L300
Re: IP location
many thanks Growlerbearnz!!!
