I've copied and pasted some quotes, and bolded the part numbers in question....
Subject: HD springs and shocks
jessef wrote:Verified !macro wrote:Can anyone verify this?Mr. Pistachio wrote:Is it ok to assume for procomp ES9000 shocks?
stock
913515
919520
w/ 2'' lift
915515
921520
Antoine
The Landy springs part # RFR-20HD - do work and give a solid 2 inches of rear lift on a LWB L400. Only mod required is to cut an file down to shape on end which take 10 mins or so.
DIFFERENT:
Subject: L400 stock shock upgrade?
jessef wrote:front 14.5 stroke length
rear 23.5 stroke length
In my opinion, you would be better off with Procomp or Bilstein's than Rancho's unless you sandblast and repaint the Rancho shock body. They are prone to rusting. However, there are people riding on Rancho's and love them. Personal preference.
ECS - ride height adjustment. It comes stock on Royal Exceeds, most Super and some base Exceed's. You'll see the ECS button beside the hazard light button in the middle of the dash. Also the ECS shocks are pin top/eye bottom. The non-ECS shocks are eye top/eye bottom.
Procomp part numbers
Front : 914510
Rear : 923510 (ECS) / 923509 (non-ECS)
You'll need 5/8 poly bushings to replace the rubber one's that come with the procomp's. Part number : PV2028
Bilstein part numbers
Front : F4-B46-2109
Rear : F4-B46-2111 (ECS) / F4-B46-2110 (non-ECS)
The Bilstein's will have the best ride. The HD Bilstein shocks are suited specifically for the L400's. They are amazing shocks.
Subject: replaced front shocks on our L400 ... what a difference
northriver wrote:Replaced the front shocks on our L400 yesterday ... what a difference in the ride!
We were getting a slight vibration through the steering column before at highway speed and this is gone now.
More importantly ... the van does not bounce badly when going over bumps (like speed bumps) at low speeds.
I am very curious to see how the van handles on the highway in windy weather now, and I am wondering if I should also replace the back shocks now.
I ended up going with Pro Comp 9000 series shocks (Ordered 2 x 914510 for the front from Lordco w/ replacement bushings PV2028). Lordco did not end up having the replacement bushings on hand after saying they did not need to order them over the phone ... it can be very frustrating dealing with them!
If you think your van bounces around a lot I would definitely think about replacing the shocks.
Subject: Pro Comp shocks part #s
cantelog wrote:im buying these shockies
ES9000 Series Shock Absorber - 913515
and ES9000 Series Shock Absorber by Pro Comp - 919520
the pictures from this site im buying from http://www.4wheelparts.com/ show the shockies to have round connection at the top and bottom of the shock, but i know from just looking at my L300 front shocks that i need a round connection on one side of the shocky and a pointy connection on the other side...
as you probably have noticed im a freakin newb when it comes my van, but im learning slowly.. any help would be greatly appreciated as i would love to get this order finalised.. thankyou
plus this is my first post :)
curter wrote:These are actually what I ended up going with (by recommend from jfarang). Installed and working beautifully.
Procomp 9000 series.
Front shocks : 914515
Rear shocks : 921520
5/8" hourglass Polyeurethane bushings : PV2028
Could someone explain the difference in numbers? I want to order these for an upcoming trip.
Is the front 914510 or 913515 or 914515?
Is the rear 919520, 921520 or 923509 (923509 didn't come up in lordco's system)?
Thanks in advance!
  Measure 37" at the top of the wheel well. Thats where my van sits with the new rear springs.  Hmm?
