Hi All,
I just replaced the gasket on my '87 L300 sunroof. It is the type over the second set of seats. The problem that I had even before I replaced the gasket, is that the sunroof wouldn't close all the way unless I pushed up on the rear and "helped" the motor. I noticed when I took things apart for the gasket replacement, that there are two adjustments possible on the rear mounts. One is a plate on the track itself, and the second is on the carrier which has one screw in a slot. Has anyone the specs or ideas on adjustment? I have also cleaned all the grease off and relubed with silicone.
Erich
						Sun roof adjustment
Does your Mitsubishi L300 make a strange noise?  Need wheel alignment specs?
				Erich
- Vehicle: Mitsubishi Delica Exceed 1987
				Jump to
	- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
