This morning it was only -2C and very humide and my Deli had a very hard time to start.. I'm scared for the -30/-45 of Cold lake.
Winter!!!!
P.Gaudreault
- Vehicle: Mitsubishi Delica 1998 Chamonix
Winter!!!!
I'm a novice with diesel engine this winter. How do you prepare your engine for our cold temperature??? Oil, glowplugs, diesel filter ect.....
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Re: Winter!!!!
1 or more of your glow plugs are probably weak. Look on youtube how to test glowplugs. Very simple process. Get a good quality set from the JDM parts suppliers in.BC. Mardy at amazimg auto has a good set with a 2 year warranty. Pricey units but they work over a much longer period. Good idea to keep spares on hand considering where you live.... GP's are not an off the shelf item in Cold Lake!
Oil: get your oil changed to a 0W30 Full synthetic. Most oil change places have it in jugs or if you're able to do it Canadian Tire works. Mobil 1, Castrol....etc.
Does the engine have a block heater or oil pan heater? Block heater is best but a pain to install. The oil pan heater(Canadian Tire keeps them behind the counter) is glued to the oil pan. Get the one that covers most of the bottom of the pan for maximum heat transfer. I have one, works great!
Washer fluids.....the rear unit is a bag and can easily be torn by freezing fluid. Male sure you got -45 in there.
Battery/alternator test: Get these checked and make sure output is proper. Alternators push 65-80amps and 14 - 14.5 volts when working properly.
- patriceboivin
- Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=23122
- Vehicle: Mitsubishi Delica L400 Super Exceed
Re: Winter!!!!
Big Bird knows more than I do but last Spring I discovered that for winter diesel I got slightly better fuel economy by adding some 2-stroke oil to it.
They put some sort of anti-gelling agent in the diesel! I felt like when I discovered the McDonald's Chicken McNuggets might not actually be made entirely out of chicken.
- doodah
- Vehicle: 96 Delica L400 Exceed
Re: Winter!!!!
Check with Steven at Rising Sun, had the same issue...
P.Gaudreault
Re: Winter!!!!
Thank for your advice!!! I'll check my glow plug this week-end, it´s crazy how many stuff that we can learn on youtube... Last year I went bowhunting for the first time and I had never dress a deer. After couple youtube video on the subject, I shoot my deer and dress my deer like a pros ish..
I already contact Steven and he gave me some trick about my problem. Maybe it´s my glowplugs relay.
- macro
- Vehicle: L400 "The Invader"
Re: Winter!!!!
I've got a manual glow plug switch, that combined with an oil pan heater has been great for me.
-Mat
@delicacanada on Instagram
P.Gaudreault
Re: Winter!!!!
I will order new glow plugs and I will see what happen. I have a oïl pan heater too and a battery blanket.. I will installe a collant heater for this winter too.
prairiefire
- Vehicle: 1995 L400 Delica SWB
P.Gaudreault
Re: Winter!!!!
Ok this is good to know.... I don't know which one it is I buy them from Rising sun.. NGK gonna be the next plugs.
- Firesong
Winter!!!!
I use these in my l400. [img]http://tapatalk.imageshack.com/v2/14/11 ... 85ac56.jpg[/img]
Researched them on the UK Delica site.
Bought on eBay. Very inexpensive and good to go!
P.Gaudreault
Re: Winter!!!!
I don't know why but I can't see the link???
- Firesong
Winter!!!!
Just a picture. NGK y-115t1 plugs. On the UK site a few guys measured and did the math and found these plugs were a match for the l400. You can go over to their webpage and do a search.
- Big-Bird
Re: Winter!!!!
RE: The NGK number for the L400 Glow Plugs
NGK Y-115T1 crosses over to NGK 2189. Might be an update to the part number.
- Firesong
Winter!!!!
If you use the international YouTube in the UK they sell for $13 ish each. Shipping for 4 should be about 15$.
NGK y-115t1
NGK y-115t1
P.Gaudreault
Re: Winter!!!!
It´s alivvvveeee!!!! I change the glow plug and start like a new even at -12 without to be plug.
