Hi All,
I just installed a new Bull Bar on the front of my L300. It had come with the narrow type and this is the one with the extensions. Since I have all new plastic on it, and it is different than the original, I need to know how to mount my good old IPF lights. Could anyone send photos of how their's are mounted? There is a top lid on the plastic that snaps on and I'm guessing I have to drill some holes in that.
Since I'm in Seattle, I don't have a way to check on other l 300s here.
Best,
Erich
Mounting driving lights
Erich
- Vehicle: Mitsubishi Delica Exceed 1987
vernacular
- Vehicle: L300 Express LWB 5dr 4wd non turbo
Re: Mounting driving lights
tried removing the plastic top cover? there should be mounting tabs under it.
this is from when i was dismantling the front of one
( the side bits were painted black )
lamps bolted onto the top bar, and their stems poked through the plastic
i think the plastic had removable gap inserts, not sure
not sure if the mounting tabs there will accommodate non standard, sorry if this is superfluous info
