LED for compass
patriceboivin
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=23122
Vehicle: Mitsubishi Delica L400 Super Exceed
LED for compass
Post by patriceboivin »
Is it possible to replace the backlight for the compass with an LED?
I replaced the inclinometer and voltage meter lights with white T10 LEDs, but the compass is another matter: The light is inside the compass' casing.
I didn't try to open the casing, not sure how to do that and I didn't want to risk breaking the compass since it works.
The compass won't see any changes for the foreseeable future, unless someone has done this before.
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: LED for compass
Post by Big-Bird »
I have a loose compass/tempurature display from the bezel frame I modified. I have been wanting to mount it in where digital clock resides.....if it will fit that is.
I will open it up and take pics so you know what you are dealing with. I suspect the lights, if any, will be soldered in place to the circuit board.
Big-Bird
Re: LED for compass
Post by Big-Bird »
Opened up my spare temperature display and then realized you said compass which is on the ceiling on the Super Exceed. Because the compass is already LED I suspect the light cant be changed...like the one in the temp. display.
At anyrate if anyone is interested in what's inside the temp display heres some images. And there is a light in the display but its hard wired and bonded in the glass (my screwdriver is pointing to it).
patriceboivin
Re: LED for compass
thank you... I will leave it alone I think :-D
Diver
Vehicle: L400
Re: LED for compass
Post by Diver »
Compass on the ceiling? On my Super Exceed it's in the dash binnacle. Yes, it has a bulb that you can change, it's mounted in the back in a bulb holder which you undo by turning a quarter turn with a flat screwdriver. The standard bulb has a little green condom on it to give the colour, but you can bin that and mount an LED with not much effort. I went with blue :wink:
Big-Bird
Re: LED for compass
Post by Big-Bird »
Well that's a new one for me. It. Didn't know the binnacle came with 2 different digital displays. The one I opened was in/out temperature only.
Pat: if you have the dual display type that Diver showed you should go back into your gauge and see where that removable bulb is.
