L300 4D56 Oil Filter Cross References
Morganizer
Post by Morganizer »
I've combed the internet in search of oil filters, and mostly combining two lists (and adding a few more I found along the way) I put together this enormous list of cross references for oil filters:
AC PF2147
AC EUROPE (NEW) X4252E
AMC/ASAHI MO-400
ASAKASHI C306J
BALDWIN BD28
BIG A 92067
BOSCH (GERMAN) 0-986-452-042
CARQUEST 85067
CHAMP LFP805
CHAMP C-321
CHAMPION SPARK PLUG K270
CLEAN DO827
COOPERS Z1041
CROSLAND 2087
DAI-ICHI PC306
DONALDSON P502061
DONALDSON P551343
FIAAM FT 5151
FILTRON OP587
FORD E5TZ-6731-A
FRAM PH6335
FRAM PH6355
GENERAL MOTORS 25171958
FLEETGUARD LF3564
GROUP-7 L34750
GUD Z248
HASTINGS LF147
HENGST H209W
HYUNDAI 26300-42010
JAPAN PARTS JFO505
JS C306J
KIA 0K467-23-802
KIA OK467-23-802
KIA OVS01-14-302
KNECHT/MAHLE OC274
LAUTRETTE ELH4187
LAUTRETTE ELH4224
LUBERFINER LFP805
MANN & HUMMEL W927/8
MAZDA VS3Y-14-302
MAZDA VS01-14-302A
MAZDA VS0-14-302B
MAZDA VS01-13-302C
MAZDA AY10-0M-T024
MAZDA AY10-0M-A001
MICRO T7317
M FILTER MH3346
MANN & HUMMEL C321
MANN & HUMMEL WP928/81
MANN & HUMMEL WP928/83
MICRO/ADL ADC42105
MICRO/ADL T7317
MITSUBISHI MZ690411
MITSUBISHI ME201871
MITSUBISHI MD326489
MITSUBISHI 1230A045
MITSUBISHI MD069762
MITSUBISHI MD069782
MITSUBISHI MD069783
MITSUBISHI MD184086
MITSUBISHI MD326489
MITSUBISHI MQ907432
MITSUBISHIME-069782
MITSUBISHI 1230A045
MITSUBISHI MQ908508
MITSUBISHI MQ905595
MITSUBISHI MZ690071
MITSUBISHI MZ690411
MITSUBISHI MZ690411
MITSUBISHI ME201871
MITSUBISHI MD326489
MOBIL LFP805
MOTAQUIP VFL304
MOTORCRAFT FL805
NAPA GOLD 1067
NIPPARTS J131505
NISSAN 15208-HA300
NISSAN 15208-HA301
NISSAN AY100-MT024
NISSAN 15208-HA306
P.B.R. BC1211
PUREPRO LFP805
PURFLUX LS740A
PUROLATOR L34750
PUROLATOR L37560
RYCO Z313
SERVICE CHAMP LFP805#
SOFIMA SFS0688
SOFIMA SFS0688S
SOFIMA SFS0689
SOFIMA 09.23.237.40
STP LFP805
SAKURA C10081
SAKURA C1046
SAKURA C1008
SAKURA C1019
SAKURA C1044
SURE SFO4750B
TECFIL PSL327
TECNOCAR RD1001
TEXACO HSO-135
UFI 23.237.40
UFI 23.237.00
VIC (EIKEN) C306
WARNER WLFP805
WOODGATE WGL3564
WIX 51067
The best site I found for checking cross references is http://www.surefilter.com/search/main.php
2nd best is http://www.js-filter.com/catalogue/filter/28795/C306J
One thing I've learned you have to watch out for is the threads. There is a 4D56 engine made by Hyundai that takes a filter with M20x1.5, but the Mitsubishi 4D56 needs M26x1.5 threads.
Surely with all these parts available, we must be able to find decent quality filters at a reasonable price. Any suggestions?
Firesong
Re: L300 4D56 Oil Filter Cross References
Post by Firesong »
I always ordered a 6 pack of BALDWIN BD28
and the price was $17ish each from the big rig store.
Great filters.
My filter for the L400 is a bit more expensive but
still a good Baldwin.
FS
Agravelle
Vehicle: 1992 Delica Exceed Crystal
Post by Agravelle »
Hello,
do you have a website address for the big rig store. I'm in Ontario, I can't find the Baldwin filters here and every store here tells me they can get me a fram or wix for 37$ to 49$. Crazy expensive.
Andy
Firesong
Post by Firesong »
They are called 'custom truck' in Saskatoon. I think 'first filter' in Saskatoon has them as well for a bit more.
I would suggest looking for a place that carries baldwin filters and ask them to order them for you.
Mine would take a couple weeks then I would split the 6 up to a couple other owners.
With the L400 I just order 2 at a time from First filter.
Firesong
Firesong
Post by Firesong »
To find a baldwin dealer in your area go here:
http://www.baldwinfilter.com/distributorlocator.html
when you put in your postal code make sure to put in a space
no space will create an error
ie. S7E 4Y9 good
S7E4Y9 bad
Jedidiahwiebe
Vehicle: Delica L300
Post by Jedidiahwiebe »
I just love researching deals on the net.... So today I took the part number off the oil filter I've been using. It's: Hyundi 26330 4X000. So I researched that for a while and Came up with this list of supposed cross reference-ing filters. Do y'all think this is possibly correct?
The source is on this page: http://www.js-filter.com/catalogue/filter/28760/C109J
SPECIFICATION
Height 120
Ø Out 94
Thread M26X1.5
Material Metal
O-Ring gasket 62x72rnd
Valves 1.0bar/1
type full flow
OWNER NUMBER
BALDWIN B7045
BALDWIN B7014
FLEETGUARD LF3689
FRAM PH10127
HENGST FILTER H10W19
HINO 15607-1480
HINO 15607-1310
HINO 15607-1331
HINO 15607-1630
HINO 15607-1330
HYUNDAI 2630042020
HYUNDAI 26300-42-040
HYUNDAI 26310-4A000
HYUNDAI 26300-42010
HYUNDAI 26300-42000
HYUNDAI 26300-42060
HYUNDAI 263304X000
HYUNDAI 26300-42030
JAPANPARTS FO-K05S
JS C109J
KIA 263104A010
KIA OK551-14-302
KIA 0K551-14-302
KIA K551-14-302
KIA OVS01-14-302
LUBERFINER LFP 9930
MAHLE/KNECHT OC274
MAHLE/KNECHT OC526
MAHLE/KNECHT OC 540
MANN WP92883
MANN WP92881
MANN W9334
MANN W93026
MAZDA VSY3-14-302
MAZDA AY10-0H-D503
MAZDA VSY1-14-302A
MAZDA VSY114302B
MAZDA VSY1-14-302
MITSUBISHI MD184086
MITSUBISHI MZ690071
NIPPARTS J1310305
PROTON PC121101
SAKURA C1302
SAKURA C2906
SAKURA C1045
SAKURA C1047
SAKURA C1308
SAKURA C2810
TOYOTA 15601-78010
VIC C109
VIC C034
WIX 59191
Jedidiahwiebe
Am I just using the wrong filter perchance? Been using it quite a while.
Firesong
Post by Firesong »
L300 or L400?
I'm guessing if you have been using them for a while with no leaks and such your ok.
Jedidiahwiebe
L300. Yep, been quite a while no problems. I did some phone searching for baldwin bd28 filters. Found them for a good price in Kamloops 18/a filter at Peterbuilt, but I think i may have to buy 12. Anyone in the Kamloops/Salmon arm area that wants to go in on a pack?
Firesong
Post by Firesong »
Typically Baldwin cases are 6. That is what I was getting Good filters bd 28
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 »
Hi Jedidiahwiebe:
I used to get Baldwin filters @ Peterbuilt and only needed to get 1 @ a time. They need to order them in but was usually overnight. I don't use them anymore as I couldn't get the last few to stop leaking. I think something has changed with them - maybe now made in China like their fuel filters.
Larry
Rising Sun Auto Import
Morganizer wrote: One thing I've learned you have to watch out for is the threads. There is a 4D56 engine made by Hyundai that takes a filter with M20x1.5, but the Mitsubishi 4D56 needs M26x1.5 threads.
This is absolutely wrong, both exclusive Hyundai and Mitsubishi 4D56 engines need same thread oil filters.
Jedidiahwiebe wrote:I just love researching deals on the net.... So today I took the part number off the oil filter I've been using. It's: Hyundi 26330 4X000. So I researched that for a while and Came up with this list of supposed cross reference-ing filters. Do y'all think this is possibly correct ?
lrp374 wrote:Hi Jedidiahwiebe:
Larry
Hi Jed,
How are you?
Don’t worry about your current oil filters as you have used best oil filter in town.
its import cost is $10-12 each, but I got quote for all other aftermarket oil filters ( currently available from delica importers and shops ) between $3-$4 each. :o
I just have refused to import others due to bad quality.
So you have used best oil filter with affordable price! :-D
Steven :M
stock oil filter & fuel filter.JPG (136.12 KiB) Viewed 11908 times
hyundai2500 oil filters (3).JPG (98.52 KiB) Viewed 11908 times
Jedidiahwiebe
Hey Steven,
I'm doing very well. Other than that my deli is stuck up a logging road tonight with a broken off radiator drain plug. Otherwise very good.
I've pretty much given up on finding a better deal on oil filters than buying from you. These filters are costly no matter where you shop!
CYYZ Deli
Vehicle: '91 Super Exceed
Post by CYYZ Deli »
For those in Ontario, Baldwin filters (BD 28) are available at Peterbilt Ontario truck centres.
http://www.peteaccess.com/
They have about 8 stores in the province. I had to order the filters, about 2 weeks to come & they'll deliver to your door. $ 20.24 each. as of today.
Eric
Firesong
Post by Firesong »
I found if I ordered a 6 pack or case that dropped to 17$ each.
