Does anyone have a parted out IP? My Cold start lever(throttle positioning actuator) has broken off, I have no way to adjust my cold start rpm...stuck at 400rpm.
Any help or suggestions of where to look are appreciated.
Brad.
L400 injection pump parts
mac_stang
- Vehicle: 94' L400
Re: L400 injection pump parts
old school like the L300 and just add a cable for a hand throttle
Let me Ghetto that for ya
mac_stang
- Vehicle: 94' L400
Doesn't sound like a bad idea considering availability of the parts...
Brad.
Brad.
Rattlenbang
- Vehicle: delica
A diesel/injection place should be able to get parts if you give them the number off your pump. These things are pretty universal.
davidwwc
- Vehicle: 1994L400 Delica
Brad,
Will adjusting the throttle cable helps ? Do it when the van is warm though.
DC
DC
mac_stang
- Vehicle: 94' L400
Thanks for the idea David, but sadly no, if I adjust the cable enough to increase idle at start....it ends up idling at 1500+rpm when warm.
I need to replace this part. I'm getting pretty sick of chasing my tail with this van, went in because of a stalling problem, now it doesn't idle high enough for a smooth start and basically is spewing fuel out the tail pipe. Thanks for the idea though.
Brad.
Brad.
