Under braking there is a rhythmic noise, almost sounds like a branch or bag is hitting the underside as it goes around. I actually thought it was someone hammering a nail into a 2x4 at first but then I realized there was no construction around. It seems like it's in time with the revolutions of the wheel. When I brake in reverse, it doesn't happen.
No squeal or pull in the brakes. The pedal pulses slightly, but it has for a while, I think I need to grease the sliders, possibly new rotors. Also, the pedal doesn't pulse in time with the noise.
Pads were recently changed, should be loads left.
Any thoughts? I'm thinking maybe a shim fell out and the pad isn't sitting quite right anymore when force is applied and if the rotors are slightly warped it may cause the pad to thump around.
Hopefully this will rattle some memories, thanks in advance!
