As the title says, the rear blower stopped working. fuses look good, rear/front switches light when depressed. Used the translation for the interior fuse block but i cant figure out how to remove them to check them.
Any ideas or suggestions would be appreciated as i have no idea even how to get to the rear blower motor.
Thank you all in advance.
Brad.
Rear Blower quit working...
mac_stang
- Vehicle: 94' L400
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Re: Rear Blower quit working...
Needle nose pliers and a gentle pull on the fuse will yield a result.
Your fuse block should have a removal tool as well that acts like tweezers.
Getting at the rear blower....that should be a last resort. Check the relays, fuses and such items first. The rear blower is removed from under the Delica.....and its not a fun job.
mac_stang
- Vehicle: 94' L400
Sorry, i can remove fuses no prob...the translation shows what look to. e relays(next to fuse block) marked rear heater. Its those i cannot figure out how to remove.
Im at a loss, i get a quick flicker from the rear ac button while cranking the fan speed controller through its paces, but that is it. I broke the tabs off the relays next to the fuse block but they wont budge(with more than reasonable force)
Brad.
Brad.
- Big-Bird
Ah, I see. There are 2 sets of relays. One is on the fuse block itself and controls power to the entire system.
Then there is another relay mounted to the lower portion of the steering column....is it this one you speak of?
BB
BB
mac_stang
- Vehicle: 94' L400
Staring up at the fuse block, the two(what look to be relays) are on the right of the fuse block.
Brad.
Brad.
mac_stang
- Vehicle: 94' L400
Well, removed and then swapped the relays on the right of the fuse block, and nothing...removed and swapped the two relays that are mounted above the drivers left shin and she came to life.
I will look for replacements but it looks like there connection just needed to be roughed up.
Brad.
Brad.
