Need oil pan for Pajero 4M40
				geaddict
 - Vehicle: Pajero 1995
Hi Guys,
Just swapping in a L400 4M40 block into my Pajero. Swapping over the accessories I ran into a couple of problems. One I will solve by drilling a hole in the block (for the dipstick). The second is the oil pan. They are different. Mine is hooped. Does someone have an oil pan kicking around for a Pajero 2.8 4M40? Need it ASAP.
Gerry
Gerry
				Manitoba deli
Re: Need oil pan for Pajero 4M40
Where abouts are you? I can probably source one for you from my parts supplier, they have a couple pajero's for parts, and have changed a few of the 2.8L's, but if you are closer to BC than I am, it may be just as easy for you to contact them and check. I only have the l400, l300, and 2.5lpajero pans kicking around here.
Jason
						Jason
				geaddict
Hi jason,
I'm in Calgary. I called Rising sun and they do not have one. Have a call in to CCAuto to see. Just waiting to hear back. If you have another suggestion I would love to hear.
Gerry
Gerry
- Rising Sun Auto Import
We do have a 4M40 engine, which is still in good running condition pajero2800cc.geaddict wrote:Hi jason,
Gerry
We do not sell oil pan assy separately even if we part out later.
Try CC autos as my staff suggested on the phone.
If not successful, you may get a new assy from Mitsubishi Japan.
Good luck,
Steven
				Manitoba deli
Will the oil pan from your old 2.8 not fit onto the new 2.8? I haven't swapped an engine from an l400 into a pajero, so I'm curious as to why you can't just use the old one. And sorry, I don't have any other suggestions for suppliers.
Jason
						Jason
				geaddict
My original is hooped. Big hole in it from the connecting rod. I need a replacement.
Gerry
						Gerry
weld it up?  I assume it is just stamped steel....
				Manitoba deli
Sorry, when you said that in the original post, I thought it was a misprint and you meant humped. Getting it welded might be your quickest and most economical solution.
Jason
						Jason
				geaddict
Based on the condition, it is not a good candidate for welding.
Gerry
						Gerry
				geaddict
At this point I am sending emails to some UK wreckers to get one shipped in. Least expensive and quickest option to get a replacement
Gerry
						Gerry
