L400 Space Gear windshield, cab, and door needed
Moderators: delicanuck, mark
Trapper Dan
Vehicle: Delica Spacegear L400
Post by Trapper Dan »
I picked up a 1996 L400 Space Gear van that had a tree fall across it and it flattened the roof out pretty good. I pressed it straight with hydraulics but I'm probably better off with a new cab frame rail and roof section if there's one out there. I also need a passenger side door or at the very least the window track upwards of the door itself and of course the glass would be handy too. If you've got one that can be cannibalized with a reciprocating saw then let me know.
Delica with tree injury.png (438.69 KiB) Viewed 2475 times
nxski
Re: L400 Space Gear windshield, cab, and door needed
Post by nxski »
I'd be inclined to buy a cheap one on craigslist and use the one in the picture as a parts van. Between the two you could have something pretty sweet.
If the structural integrity of the vehicle has been compromised it is not legal to drive unless repaired by a professional. Have you managed to get this approved and insured?
Manitoba deli
Vehicle: 94 l300, 94 l400 lwb, 97 l400 S II
Post by Manitoba deli »
Check with Steven at Rising Sun Auto. He had 2 l400 parts vans when I was there, and I saw some structural pieces cut out of his l300's and pajero's for body shops. I'm sure he will cut up one of the l400's for you.
Jason
MardyDelica
Post by MardyDelica »
trapper dan,
pls give me a call I can help you;
Cheers;
