DIY installation of shocks?
ShaneA
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=12984
Vehicle: '94 Space Gear LWB
Post by ShaneA »
Hey there,
I'm just wondering if anyone has swapped the front shocks themselves? How difficult/easy is the job? It doesn't look overly difficult but I've only had a glance under there when checking out the really bad noise coming from my driver side front shock. Seems the bottom of the shock has rusted out and has nearly torn itself off the bottom mounting. I'm not willing to drive it until it's fixed and it would be a long and expensive tow to get it out to CVI.
Shane
nxski
Re: DIY installation of shocks?
Post by nxski »
I personally wouldn't worry about driving it. I had a shock completely shear off while taking a corner, I continued to drive it like that for another 150km before getting it to the shop to have them replaced.
Mr. Flibble
Post by Mr. Flibble »
Replacing your own shocks is only a little more difficult than replacing a tyre.
MardyDelica
Post by MardyDelica »
its not hard to replace it for 4 shock front and rear will be about 3 hour or 3.5 max depends how rusted is your shock
cheers
macro
Vehicle: L400 "The Invader"
Post by macro »
I just did mine, first time I've ever done shocks on any vehicle, it was pretty easy. You can compress the shock by hand when you put it in with a bit of effort. I had to trim down the bottom bushing a bit to make it fit properly. Easy peasy!
