Window/Door black trim
Torqueluvr
Vehicle: Mitsu Paj
Post by Torqueluvr »
Hi all,
1994 LWB 2.8 5spd Paj. This trim had been cracking ever since I bought the machine - last July - and just the other day when pulling snow off the car it finally gave way. Any advice on how to fix/replace? The metal underneath is bare and is starting to develop small surface rust.
photo 2-Optimized.jpg (36.88 KiB) Viewed 3797 times
photo 1-Optimized.jpg (17.22 KiB) Viewed 3797 times
del400
Vehicle: Delica L400
Re: Window/Door black trim
Post by del400 »
I'd take it off, clean it and plasti dip it. Any color you want.
Worked for me for some care parts.
pajerry
Post by pajerry »
Great tip, I'll have to do that at some point as they're starting to crack as well.
mitsubill
Vehicle: 1994 Pajero V26wg
Post by mitsubill »
There is black adhesive 2in trim tape that you can use to replace, just remove the original, replace and use a straight edge and exacto knife to fit in place. Can tire is where I got the tape, worked well. :-D
Return to “Pajero”
