Would this work on a Delica?
http://www.x2industries.com/front-air-s ... 7_331.html
Using a Montero air-lift suspension kit to lift the Van when needed, and drop it back down when not?
More detail here:
http://www.x2industries.com/mitsubishi- ... R6h55G9KSM
Air Lift for Delica?
- Mr. Flibble
- Mr. Flibble
Re: Air Lift for Delica?
Looked at this in more detail.
Apparently as the Delica uses torsion bars in the front you cannot use an air lift in the front.
Also someone stated before, you would need the hydraulic lift from an ride-height equipped Pajero.
