so today i tried to do a number of things to the van.
1.i set out to replace the transmission mounts as i was having a lot of vibration when stopped and in gear. i got one replaced went to the other side and couldnt get the top bolt out of the bushing so decided to leave it for now as it was raining and didnt want to deal with it.
2. replaced all of the shocks
3. changed the oil, which only gave me 4.5L but was still reading full on the dipstick before the change.
was working at a friends house so packed up to leave and van shifts but nothing happens. the lever shifts through the gears but there is no clunk or feeling of engagement and it rolls in all of the gears. i can get it to engage if i rev it to around 4000rpm and then it lurched a little bit but i didnt do that again as it didnt seem like it was a good idea.
so is it possible that in banging around on the transmission mounts or the shocks i jiggled something loose that this would happen. i didnt check the transmission fluid while this was happening but i did check it earlier in the day and was a little bit low, decided that i would need to check it again when running to make sure level was alright.
any thoughts or suggestions. i moved the van in the middle of the work before the oil change and after the tranny mount debacle and changing both front shocks.
Transmission problem, shifts but doesnt go???
the lorax
- Vehicle: 93 L300
- TardisDeli
Re: Transmission problem, shifts but doesnt go???
Is the kickdown throttle cotter pin still attached. Standingby pasenger door, with seat up, look at accelerator between engine and IP), see the orange rubber crumpled part, which moves when you press deisel foot pedal. this is held together with a tiny half inch cotter pin. which breaks with age. Sending u the home ph number via PM, we're in Burnaby, call us up till midnight tonight if you need (your symptom of high rev sounds like this). cheers christine.
Christine
the lorax
- Vehicle: 93 L300
great thanks for that i unfortunately wont be able to get back down to the van till tomorrow am, but will check out the cotter pin. and if i have issues with it i may give ya'll a call tomorrow
cheers
cheers
