The good news is the head gasket for the Dodge Ram is correct; it looks identical to the one that came out of the van. The bad news is the head is cracked in each cylinder between the valves, and in cylinder 3 between the precup and exhaust valve. The latter looks ugly and I suspect the head is toast. I'll show it to my machinist and see what he has to say about it. I suspect that isn't where the coolant was getting into the engine though; there was waaaay too much white smoke, and I doubt there is a coolant gallery there anyway.
I also discovered that Belt B was broken, although there's a sticker on the belt cover saying the timing belt was done 50k ago. Is it possible some lunkhead would do the timing belt but not the other one? Lucky it didn't trash the engine by taking out the timing belt. My turbo also needs a rebuild as its got significant oil leak issues. No bearing play, which is good.
