Winterize....Alberta bound.
prairiefire
Vehicle: 1995 L400 Delica SWB
Post by prairiefire »
Hello All!
I'm soon to be Alberta bound for work and was planning on driving out from Vancouver. Can anyone give me any tips on extra precautions I should take. Any thing special I should do to winterize the beast. Thanks in advance.
K
drrod
Vehicle: 93 Exceed
Re: Winterize....Alberta bound.
Post by drrod »
Nothing special. Just make sure your antifreeze and cooling system are in good shape.
In block plug in heater, synthetic 0-30 or 5-30 oil and a battery maintainer and you should be good to go.
Rod
CREGAN
Post by CREGAN »
drrod wrote:Nothing special. Just make sure your antifreeze and cooling system are in good shape.
Rod
I run 15w40 synthetic and my coolant is good past -38. Make sure your glow plugs are up to snuff and bring an extention cord to plug it in. You will do fine. Where abouts in Alberta are you bound?
Craig
prairiefire
I've already got a block heater but I was thinking of getting an inline coolant heater installed. Was gonna flush the coolant system and go with new fluid and thermostat at the same time. Glow plugs are fine (2 years old). Haven't touched the IP seal yet, but I have no issues starting out here. Gonna stick with reg 15w40 though. I've got 3 pails of it to go through from a Walmart deal. Looks like I'm heading out towards Ft. Mac. Not sure yet....waiting on my call. Pipeline Bound!!!
CREGAN
Post by CREGAN »
Yeah it gets pretty cold in Fort Mac. I was going to say the inline heater was a bit much, but where you are headed that is a good idea.
Craig
Mr. Flibble
Post by Mr. Flibble »
Fort Mac? A battery pad heater may be a good idea too. I think a charger will keep the battery somewhat warm, but a battery pad heater is effective and inexpensive.
prairiefire
Battery Pad heater....is that like a battery blanket? I'm going to a camp job so my van will be sitting around and not being driven. Was gonna fire it up every Sunday (my day off).
Mr. Flibble
Sort of:
It sits under your battery, so if you can plug in your block heater, you can plug in the pad too, and it keeps the battery warm.
CREGAN
Post by CREGAN »
Mr. Flibble wrote:Sort of:
Plus you can get a little inverter and you can sit on it as drive back to civilzation from Fort Mac! Multi-functional seat warmer. ;)
Craig
Mr. Flibble
CREGAN wrote: Plus you can get a little inverter and you can sit on it as drive back to civilzation from Fort Mac! Multi-functional seat warmer. ;)
Craig
LOL! Heck, if he is going to Fort Mac, and does not have heated seats, then I would HIGHLY recommend he install them. Costs about $55/seat and takes less than 2 hours per seat. In fact, would probably take less with the walkthrough I posted.
prairiefire
drrod wrote: Just make sure your antifreeze and cooling system are in good shape.
Rod
What do you mean by that exactly? New A/F and a good rad/water pump and thermostat. Just curious about what could go wrong if I'm ill prepared.
k
NoDelie
Vehicle: pajero exceed 1989
Post by NoDelie »
I live in Calgary and i have a oil pan heater,block heater and run synthetic oil. If you run 15/40 you could blow a head gasket. Even if you just have a block heater, that is good. Heat you oil
Smile, your boss will wonder.
Firesong
Post by Firesong »
Biggest thing is block heater. 2nd is synthetic 0/40 or 5/40 oil. 3rd good batteries. The rest is trivial.
alti2d
Vehicle: 1992 Delica L300
Post by alti2d »
I'm in Fort Mac and do just fine with a block heater (required) and 0w30 synthetic (much better than 15w40). And about 15 minutes of warm up time before heading out. If you end up in town we can have a deli meet. :)
drrod
Vehicle: 93 Exceed
Post by drrod »
Rod
k
Just make sure that the coolant is relatively new, good for -40, water pump in good shape, no big leaks, etc.
BTW, I would save your 15w oil for summer and change out to a lighter weight for winter.
Rod
