Tachometer stopped working
temsinc
Vehicle: 1997 L300
Post by temsinc »
I have a 97 L300 fresh off the boat. My tachometer was working fine, but after the Alberta out of province was completed (how ironic :-D ) the tachometer does not work. I have no idea if there is a direct correlation between the OOP and tachometer not working, but the're were daytime running lights installed. Suggestions?
Finally, does anyone have a NAPA or CAN Tire part number for a block heater (frost plug). Thank you in advance.
Mr. Flibble
Re: Tachometer stopped working
Post by Mr. Flibble »
This thread might help you get pointed in the right direction:
http://www.delica.ca/forum/need-a-tach-signal-2324.html
I don't have a L300, so I can't look at one for comparison.
temsinc
Vehicle: 1997 L300
Post by temsinc »
All fixed. Chased electrical from injector pump to instrument cluster. As soon as we unplugged connector and reconnected it to the instrument cluster, the tachometer worked. Thank you Mr. FIBBLE. :-D
