I finally tracked my starting problems down to the power (ie, starter motor) side of the starter relay behind the drivers seat. In the process of trying to pull out the female electrical pin from the OEM plastic plug housing, everything went to crap... So I'm looking for a spare OEM plastic housing and female connectors for the starter relay.
I do know what the workaround is, but it'd be nice to keep the OEM stuff in there if I can find it. If you can help, please let me know.
Starter relay electrical connector
Moderators: delicanuck, mark
alti2d
- Vehicle: 1992 Delica L300
alti2d
Re: Starter relay electrical connector
Just for those who might be interested,
Found out that both a wire into the OEM plastic electrical connector was loose (i.e.: broken), also found that the relay burnt out.
Got a new relay, then managed to find the OEM connector through EasternBeaver.com. These are the .325 electrical connectors. They seem to be a little difficult to track down locally, so this was a good find.
