no power to after turning the key to start
Pajero
Vehicle: 94 Pajero
Post by Pajero »
ok so today after Turning the key to start the pajero up there was a click then all the power was gone no lights...no power to anything checked the fuses and wiggled some wires and it starts and runs fine....turn it off and same thing....
any ideas? could a bad starter cause this?
thanks
Joe
Orionsbelt
Vehicle: '90 Pajero LWB 2.5 TDi
Re: no power to after turning the key to start
Post by Orionsbelt »
So you got it started by the sounds of things...
Yrs ago I was given a trick with starters...bang them lightly with a hammer to get them to work. That said if you're having to do that means the starter is on the way out.
Alternator or wires going from them. Something isn't connecting to something else... There's a wire going into the back of the starter. I noticed on mine it wasn't exactly tight. If it's loose you could get some funkiness...
Batteries
I've seen odd behaviour now with the batteries needing changed...power but not enough to turn that diesel beast.
And when the alternator went...
Orion
Before you rebuild the starter and the alternator, I would recommend cleaning the terminals & cable ends. A change in weather can create a vapour barrier between the battery terminal and the cable end, inhibiting the charging process. This is simple to address and a lot cheaper than rebuilds.
If it is the starter, then going by my experience ~ if you find yourself hitting the starter to get the solenoid happening, it usually means that you have roughly six more starts left. At least with the Chevy engines. Also, I would avoid cranking the starter for more than 30 seconds as it over heats the brushes, especially on our vehicles as they crank faster.
Another potential scenario is your battery(ies) is on it's way out. Cold is famous for killing any weak batteries.
403delica
Vehicle: LWB L400
Post by 403delica »
Sorry if its and L400 there is a ten mill nut on the positive lead if the battery cable that hold some relays and it gets loose... Happened to me the other day turned on then nothing... Just tighten down hopefully that's it
Pajero
Vehicle: 94 Pajero
Post by Pajero »
ok found the problem! it was just a bad ground to the frame, i guess the starter takes so much juice that it killed the poor connection that was there. so new cables tomorrow and I will be set!
Joe
Oh and to test the problem I just took the jumper cable from the neg terminal on the battery to a bolt on the frame and it started right up.
Return to “Pajero”
