Just a quick blurb to show how I installed my Coolingmist Stage One "trunk mount" injection kit. 279.00 shipped (Blaine Wa) care of Ebay!
  The trunk mount is pretty cool as the pump is mounted within the tank to save space...it still features a full 4 litres capacity.
  I had already relocated my auto transmission cooler so I was able to use the free space to mount my injection tank.  I designed the aluminum mounting straps to allow the tank to "hinge" down to slide the tank out to fill.  One wing nut secures the entire thing....waaaay over built, but cool (I think) none the less.
  The tank is in the coolest spot it could possibly be mounted(..get it?? lol)  access is quick/clean and easy for filling.  I mounted the one nozzle on the EGR block off plate on the intake manifold, as it sees the most turbulent air flow and can spread the mixture evenly amongst the cylinders...works well.  It did lower the EGT's by over 200*.  I currently have it set at 10psi.
  I designed a cover plate out of ABS which I molded with a heat gun.  It affixes using the same wing nut as the mounting straps.
							Alcohol/water Injection Install Made Easy
- bionic
- Vehicle: 92 delica exceed
				- More aerodynamic than before...if you could call it aerodynamic!!
- GEDC0063.JPG (184.96 KiB) Viewed 3417 times
				- ..uber space without the old trans cooler
- GEDC0079 1.JPG (200.13 KiB) Viewed 3423 times
				- I think it looks OE...and maybe a little menacing...or not!
- GEDC0067.JPG (184.39 KiB) Viewed 3423 times
				- The whole thing simply slides out onto the ground for refilling...no messes to worry about.
- GEDC0078.JPG (135.68 KiB) Viewed 3424 times
				- ..good old 1/4" ABS sheet to the rescue again, between the tank and the cover, should be good for a few good hits!!
- GEDC0083.JPG (100.69 KiB) Viewed 3424 times
				- A little overkill on the straps, but I seem to have an abundance of aluminum and stainless around. Note the use of the step mounting bolt for the strap anchor. The tank "rests" on the rear of the step.
- GEDC0071 1.JPG (128.19 KiB) Viewed 3424 times
				- Checking fluid levels should be easy now!
- GEDC0030.JPG (111.3 KiB) Viewed 3430 times
- bionic
Re: Alcohol/water Injection Install Made Easy
***Just an update.  I originally chose to run this system for its ability to lower the intake temps, it seems to offer a far greater benefit in the way of added power.  The only "real" change in EGT's seems to be with running water only, having it  come on at 8-10psi for climbs.
I prefer to use a 50% Ethenol/50% water mix which keeps the EGT's stable but had proven to really perk things up off the line engaged at 9psi. I can now confidently say it will add power safely to these low powered diesels. I use roughly 4 liters of alcohol/water mix for every tank of fuel at 10psi. (500kms)
				legionnair
- Vehicle: delica L300
Thanks for the great info
