SS exhaust and snorkel
nxski
Post by nxski »
I'm thinking a double stack 2.5" exhaust paired with a snorkel would look neat. I have a new connection for metalwork so thought this might be a good first project to start him on. Basically it looks like I just send the tubing in where a normal snorkel would go, plumb it into the airbox and then out to the engine!? I fail to see the reason for a trap since the airbox would do this. Can anyone see a problem with this or have a suggestion to make it cooler?
Re: SS exhaust and snorkel
6" side pipes (both sides) and a rally vent on the roofline - that would be cooler!
nxski
Post by nxski »
I'd be up for larger pipes and one on each side. The roof vent is pushing it considering how busy it already is and it would just be stuck to my sun roof. Do you think it would be possible to vent the exhaust out the other side without bringing it down so low as to give less clearance for offroading? It seems as though I'd have to have it bent under the transmission!?
Big-Bird
Vehicle: 96 PE8W Spacegear
Post by Big-Bird »
You going for some quazi Bosozoku Style pipes??? I know you'll keep it slick and clean.
nxski
Post by nxski »
Big-Bird wrote:You going for some quazi Bosozoku Style pipes??? I know you'll keep it slick and clean.
Bingo! I'm hoping not as ghetto though. I could clamp them to my roof rack and have them dump / suck just above the roof
rezdiver
Vehicle: 1991 L300
Post by rezdiver »
let me know when you re-open. :wink:
Reza
1991 Delica L300
http://www.iltisforum.com/
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
Intervention time?
nxski
Post by nxski »
thedjjack wrote:Intervention time?
Really!? Coming from the ghetto snorkel? :-D
you piqued my curiosity. I'm sure between you two, you can come up with something 'different' :-D
thedjjack
Post by thedjjack »
Somebody, stop the madness!
Big-Bird
Post by Big-Bird »
Seriously though.....
As long as the exhaust isn't to close to the intake, which means keep the spent gasses away from the clean(er) air intake stream the final look could be quite fetching.....
What about the heat from the exhaust? Given any thought on preventing plastic warp or people getting burned from accidentally touching the pipe? You would also need some way of keeping rain and snow from entering the vertical tail pipe when parked..unless you put a tractor flap on it.
nxski
Post by nxski »
I was thinking of having the exhaust bent back and the snorkel bent forwards as for heat...don't be stupid and touch it, maybe a sticker!?. :-D what plastic would be warping?
rezdiver
Vehicle: 1991 L300
Post by rezdiver »
nxski wrote:I was thinking of having the exhaust bent back and the snorkel bent forwards as for heat...don't be stupid and touch it, maybe a sticker!?. :-D what plastic would be warping?
That would go over real well in court, after little 4 year old timmy leans over to touch the shiny pipe in the mall parking lot and his hand melts to the pipe. "Sir I did have a warning sticker on it but it must have melted off from the heat, that little s^!t should have known better than to touch my van" :-)
Reza
1991 Delica L300
nxski
Post by nxski »
I'll just put the sticker next to it. Semi's have exposed pipes and I've never heard of someone being taken to court for that. :?
