A question about galvanic corrosion
sfd_656
- Vehicle: l400
I am rebuilding a utility trailer that has a steel frame and an aluminium floor, the steel is freshly painted with tremclad rust paint, the aluminium floor is raw aluminium. Do I need to be concerned with galvanic corrosion or will the paint on the frame be enough to stop the effects?
Re: A question about galvanic corrosion
Many people use raw aluminum roof racks against painted steel roofs so I would assume that should be fine. This also brings up an interesting point that I've been meaning to voice, which is that if galvanic corrosion is such an issue how is it possible that we're driving 20 year old vehicles with Aluminum heads on them and cast iron blocks!?
403delica
- Vehicle: LWB L400
galvanic corrosion only occurs on untreated exposed metal so in the case of a head and block we have a head gasket separating the two... as far as the trailer i say your good to go... you could by a 2mm rubber sheet and use it as a isolator between bed and frame maybe
yojimbo
Yup it occurs between steel and aluminium where they are actually touching and bare.
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
legionnair
- Vehicle: delica L300
This is possible because of the coolant. Take out the coolant and put in straight water it won't last very longnxski wrote:Many people use raw aluminum roof racks against painted steel roofs so I would assume that should be fine. This also brings up an interesting point that I've been meaning to voice, which is that if galvanic corrosion is such an issue how is it possible that we're driving 20 year old vehicles with Aluminum heads on them and cast iron blocks!?
Dustin
elderberry
- Vehicle: Delica
It will also occur with painted materials if your using dissimilar metal mounting hardware, in aviation we use a jointing compound, or a primer on the rivet/fasteners.
The rubber mat or even a good tape between mating surfaces is effective.
One Life, Live It!
sfd_656
- Vehicle: l400
I decided to use old truck inner tube butchered and laid out on the steel frame. and will use primer on the hardware to attach the floor to the frame.
PS a 7'x9' sheet of aluminium is heavy when you are trying to maneuver it and not scratch the paint
yojimbo
A 7 inch by 9 inch sheet?sfd_656 wrote: PS a 7"x9" sheet of aluminium is heavy when you are trying to maneuver it and not scratch the paint
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
