Hi there
My '94 L400 has had a good history (2+ yrs).
It has had small issues of not shifting - holding at higher rpms then doing its thing, but good for the most part. At cold start up it holds at about 60kmh for a bit before shifting. At present the tranny fluid - good level and maybe a little off color (some brown). (What type of fluid?)
Lately I've had issue where it causes the vehicle to shake a bit between 20 - 70kmh. When I take the OD off, it dampens the effect but it is still noticeable. At 80kmh+ I can feel some vibration and it sort of sounds like the vibration and subtle lurching chugga-chugga-chugga you feel near a train. It is getting a little louder and while not a huge deal I can certainly hear the change in the vibration. At low speed idle, if I simply let the vehicle go I can feel the vehicle do a go-pause-go-pause kind of subtle lurching. At the same time I can hear a squeak in the back end that coincides with the lurch rythm.
Should add that the rpms are consistent - they don't bounce around at all. Acceleration rpms is as has always been - fuel lines seem to be smooth.
I've read through the forums - wondered about something in the brakes seized? Maybe TPS? Tranny?
Anyone have any thoughts?!
This will be the first trip to the shop with me. Hopefully I can find someone good in Red Deer, Ab to work on her. It would be nice to go in with an idea of what we're possibly looking at. :)
Shimmy, lurch, squeak on L400
stonefly
thelazygreenfox
Re: Shimmy, lurch, squeak on L400
Stonefly (fisherman? I guess)
Take it to a brake shop for a free estimate. Tell them you'll come back in a week if you don't want the work done by them.
My first guess is warped front rotors, but a shop can tell you quickly. You can do all the work if you're handy with tools.
Good luck
TLGF
Good luck
TLGF
does it sound like this accompanied by lurching? http://www.youtube.com/watch?v=Um-CF2NNfVM
also tires that are not properly balanced or out of round can cause shimmying at various speeds
stonefly
I took it in yesterday afternoon. There is a wee wearing on the inner front tire - possibly a bearing issue with possible lump in the tire. Ah, but in 2 quick test drives did the e-brake test of the rear brakes. They wanted to have a look at the brakes today (I'm checking her in now) as well but nothing really stood out on the test drives. But when I got home the rear pass side brakes were smoking from the use of the e-brake. So, likely the rear brakes were seizing and the heat has warped something to egg shape giving a bizare lurch feel. Was wierd that there is no grinding, etc felt in the braking to lead to this, but sometimes these things go that way. Ah well, a little more $ as I'm sure there's a few melted parts in there. And the tires are Yok AT/S so I might have to replace one of them too if the tire is no good. Funny how these things go.
Thanks for your time.
PS - no sound like that vid! Thankfully. :)
