I drove my Deli To the Grocer, and on the way there, there was a lot of clicking behind the seat from the relays(?)any way now it will not start. Turn the key and a click but it wont turn over. Any ideas.
Val
Won't Start
Re: Won't Start
Sounds to me like you may have had an ECU problem ( clicking ) which may have left the glow plugs on and that killed your battery. Try to give it a boost but if the clicking starts when you attach the booster cable you likely won't be able to get enough power to start. If this is the case disconnect the battery and charge it completely and then try to start it. Good luck!
- Shaun Van Ramen
- Vehicle: '91 Exceed
Re: Won't Start
I started it by jumping the starter, so power is not getting to starter. ECU then?I had this problem before and the a wire coming off the + terminal of the battery was corroded, but it looks good now.
legionnair
- Vehicle: delica L300
Re: Won't Start
No ECU for starting, check the battery for failure, then when running with all loads on check your charging voltage should be around 14.5v, also check the fusible link just above the battery.
Good luck
Good luck
Re: Won't Start
Well I might have screwed up in the past. I took the fuse out and wired it directly on an emergency road repair and forgot to replace it. It is showing the same symptoms so it could have blown further up the chain from the fusible link. Any ideas where it ties into?. A switch maybe.Battery and alt are good.
legionnair
Re: Won't Start
Fusible links are hooked to the battery, sounds like you need to check with a volt meter from the starter signal circuit while turning the ignition and start following the wire. Until you find voltage.
Tough one good luck
Dustin
Tough one good luck
Dustin
Re: Won't Start
If you got access to a multimeter you can use this drawing found in the technical section ( just above L300 ) to check your fusible links. the drawing may not be exact but they are usually pretty close.
Good Luck.
http://www.delica.ca/manuals/L-300%20Ma ... wiring.pdf
Good Luck.
