Series 1&2
doodah
Vehicle: 96 Delica L400 Exceed
Series 1&2
Post by doodah »
What is the difference between an L400 series 1 and series 2?
CREGAN
Re: Series 1&2
Post by CREGAN »
Tame looking front end redesign. I think that is about it.
Craig
Manitoba deli
Vehicle: 94 l300, 94 l400 lwb, 97 l400 S II
Re: Series 1&2
Post by Manitoba deli »
Yeah, different front clip, and the injection pump has an electronic govenor and throtle control. Still a mechanical pump and injectors, just electronicaly controlled. Also some funky carpet patterns.
Jason
Manitoba deli
Re: Series 1&2
Almost forgot about the auto-extending step for the sliding door. It was on all the series 2 that I was looking at, but it may be a grade option. Pretty handy though. The steps are otherwise useless the way they are tucked under the body. The other main difference is price. Quite a bit more for the series 2. Crystal lite's are not as easy to find, hundreds of Chaminox though.
Jason
Mr. Flibble
Re: Series 1&2
Post by Mr. Flibble »
Series 1:
Compression ratio — 21:1
Power — 92 kW (125 PS) at 4000 rpm
Torque — 294 N·m (217 lb·ft) at 2000 rpm
Series 2:
Fuel system — Electronic control type distribution type jet pump
Power — 103 kW (140 PS) at 4000 rpm
Torque — 314 N·m (232 lb·ft) at 2000 rpm
Wobby
Vehicle: 1994 L400 Super Exceed PF8W LWB
Post by Wobby »
And a different auto transmission :)
