Binnacle temperature probes
- Big-Bird
- Vehicle: 96 PE8W Spacegear
So I tracked down a binnacle/dash top gauge cluster for my L400 and it needs the temperature probes to make the temp gauge work. Anyone know were I can get a set (internal and external) perhaps even a set from another vehicle that can be adapted?
madmazda
- Vehicle: 1994 l400
Re: Binnacle temperature probes
should already have them the inside one is attached underneath towards the bottom of your steering colum and the outside one is located behind your front bumper...
- Big-Bird
Thanks MM I will check those areas. But my L400 didn't come with the binnacle cluster originally. The wiring harness that would normally be in the dash, well to put it simply....isn't there.
madmazda
really wow well lets hope the wires are tucked away someplace the temp probe inside is just near the steering wheel lever that adjusts the tilt, it's black and loos like a tear drop sort of
