fuel leak injector pump
GHC
- Vehicle: delica L 300
Delica L 300 diesel leaking from right front side of injector pump. Small cover on r.f.side 2 bolts hold it on leaking from gasket. trying to find an exploded view of pump to find out if I can pull cover tofix gasket.
- CVI
Re: fuel leak injector pump
You can try and replace a viton o ring but be careful on taking the cover off as it might have the spring and washers with it. The problem with the fix is that it may leak somewhere else in the future....but it will solve the leaky issue for now. Good luck.
Hi GHC, welcome to Delica Canada
Go to: L300 Dedicated Category Reference Forum/L300 Shop Manual Downloads. Have a look round and see what you find... smiles.
P.S.: I have moved this topic to "L300 Technical".
