l400 keyless entry.
mrraulduke
- Vehicle: 96 L400 SWB
l400 keyless entry.
my van came with only 1 key, and it has a built in keyless entry lock/unlock buttons on the key body. does anyone know if i can get an extra one, or a key fob that works?
thanks
thanks
Re: l400 keyless entry.
I took mine to best buy and future shop installers. They couldn't find the match up code to program a new one.
Ended up just buying a $100 remote starter set with free install. Came with a pair of fobs. Now the Chamonix can be started and unlocked remotely.
They said its cheaper to buy a new fob set than to find and reprogram an old JDM one.
Hope this helps
Hope this helps
mrraulduke
yeah,
that is what i thought i'd have to do. as it it the keys i had cut at home hardware didn't work in the doors, and had to be jiggled in the ignition. so off to a proper locksmith tomorrow to get it working properly! just thought it would be cool to find a matching key.
Feds
I'm seriously considering ordering one of these:
http://www.ebay.com/itm/NEW-Keyless-Ent ... bb&vxp=mtr
Failing that, maybe source a USDM control box and see if it plugs into the factory harness.
- Mr. Flibble
Any idea of how long of a range you can get on remote starting?
I would love to start the Deli on the Ski Hill before I get to it. Assuming the remote start handles winter conditions.
I can start mine from about 200m away with direct view and more like 50 without. One time I managed to accidentally do it from 3 blocks away while at work though (no idea how that happened since visibility was non-existant and it requires you hold the button for 5 seconds, release and then press again...my pocket has skills!)Mr. Flibble wrote:Any idea of how long of a range you can get on remote starting?
For an alarm, power locks, imobilizer, remote start, turbo timer and install I paid $300.
mrraulduke
I'd want all of the above, minus the alarm. Anyone know if you can get these kits and NOT have the alarm?
- Mr. Flibble
Yes, they can be had sans alarm.mrraulduke wrote:I'd want all of the above, minus the alarm. Anyone know if you can get these kits and NOT have the alarm?
What I would like to know is if it would be possible to wire in the circuit to a 4 ft CB antenna and amp for insane range...
- doodah
- Vehicle: 96 Delica L400 Exceed
Hey Jesse, can you let me know where specifically you had your keyless kit installed?
Glenn Delwood
- Vehicle: 1995 Royal Exceed
+1 on what's written above. My remote ended up in the dumpster, if I were to guess.doodah wrote:Hey Jesse, can you let me know where specifically you had your keyless kit installed?
- Big-Bird
- Vehicle: 96 PE8W Spacegear
What remote start model did Jesse install? These units are not all compatable with the diesel's glow system. And +2 what shop did the install? A few places i went to in Calgary were hesitant to even quote a lump price...they wanted a per hour rate and said it could take up to 8 hrs to install......Didn't want to say goodbye to $1000.00 so I backed off.
I got mine done at Performance Car Stereo in North Vancouver. After six and an half years ~ the love is still there, one of the better choices I have made in my lifetime.Glenn Delwood wrote:+1 on what's written above. My remote ended up in the dumpster, if I were to guess.doodah wrote:Hey Jesse, can you let me know where specifically you had your keyless kit installed?
P.S.: If you do go there, tell them Falco sent you. Not sure if they will give you a deal but they might give me a beer. Cheers!
Yukonflyer
- Vehicle: White l400 Super Exceed
Big-Bird wrote:What remote start model did Jesse install? These units are not all compatable with the diesel's glow system. And +2 what shop did the install? A few places i went to in Calgary were hesitant to even quote a lump price...they wanted a per hour rate and said it could take up to 8 hrs to install......Didn't want to say goodbye to $1000.00 so I backed off.
Hey Big-bird,
It's a couple months later, any luck finding somewhere to get a remote start installed in Cowtown for a reasonable price?
I just finally got my l400 and am interested in the same thing.
You don't find adventure on the couch, Get Outside and Live
stever1000
- Vehicle: 94 L400 SuperExceed
Has anyone installed keyless entry themselves? I would like it to simplify locking the doors while camping
thanks!
thanks!
Feds
I did the Canadian Tire remote start. It's a lot of wires, but was more tedious than difficult. A straight Keyless entry should be an easy weekend job.
