New Performance Tool
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 »
I got a new Garmin GPS last year and have been playing around with the tracks feature. The graphing feature is kind of neat. If you have a nice consistent hill it's really easy to do performance tests that are real instead of just 'it feels like more power'. The green trace is elevation and the blue is speed. The only real variable is wind which we all know can screw up any hill climb.
I also got the Backroads GPS BC map for it which is also a great tool. The USB connection appears to be a bit flaky but I'm not sure yet if it's the GPS or the map file.
West of Manning
West of Manning
H-P 1.jpg (14.32 KiB) Viewed 2832 times
East of Manning
East of Manning
H-P 2.jpg (13.03 KiB) Viewed 2832 times
thelazygreenfox
Re: New Performance Tool
Post by thelazygreenfox »
Great feature, :-D I'll look for that in my next Garmin. I have both speed and elevation features in myVista HCX but can't graph. Awesome!
TLGF
Artacoma
Vehicle: 97 V6 LWB
Post by Artacoma »
Thats a cool feature , I have a built in garmin based gps in my vans stereo ,I'm going to have to see if I can extract any data like that to my laptop.
Rik
97 Series 2 V6 LWB
lrp374
Post by lrp374 »
I think the instantaneous readings from this system may not be to accurate. I can remember needing to use the brakes a little but I'd think -107% grade would really be noticeable. It would have been interesting to see what the inclinometer said!
Mcgillvary
Mcgillvary
McGillvary Lk Rd.jpg (26.54 KiB) Viewed 2676 times
Could be how many satellites were on you at the time. To get an accurate reading in 3D you need to have at least four tracking you at any given time. Typically there are thirty active satellites in the heavens all around the Earth, it's quite possible that at times you were only being tracked by three, or two even. I once drove from Longview to Highwood Junction, then down past Livingston Falls to Coleman and the Frank slide and there were a number of times that one of my tracking satellites orbited over the Rockies, beyond sight and I would get slightly off elevation readings.
snelson
Vehicle: 92 Delica Exceed
Post by snelson »
"....at least four tracking you at any given time" I know it's just wording, but satellites don't track you.
GPS receivers receive a timing signal that satellites send out....carry on :M
snelson wrote:satellites don't track you.
maybe it's sprinkled with pepper
snelson wrote:"....at least four tracking you at any given time" I know it's just wording, but satellites don't track you.
LOL... Good point, if they were tracking me then I would expect I would warrant all thirty.... or not.
I have a feature on my system that informs me of how many and which GPS satellites are in range of my GPS aerial ~ sometimes I get as many as nine, occasionally three or two. This would typically occur in a deep valley, &c.. In the case of my previous post I was driving beside the Rocky Mountain Range, a rather high fence as it were. And then there are power lines...
