Hi. My name's David and I have a 91 Star Wagon on the way. I live in Courtenay and I'm considering modifying the vehicle to run on WVO. I recently lost some of my enthusiasm after reading that WVO horror story. Does anyone have any redeaming thoughts or experiences to share?
I understand there is business in Campbell River that will do the conversion for somewhat over $2000. How much less would it be to do it oneself?
David in Courtenay
Frisch
- Vehicle: Mitsubishi L400
Adam
Re: David in Courtenay
I did my installation for about $900 given all the misc. parts I've added, like:
There are several other good descriptions of WVO installations on the site as well, that if taken together should provide a balanced view of the process. You should also know that the sum total of my automotive service experience prior to this project was changing my oil, and badly at that.
- Plant Drive kit
Aux Electric Fuel Pump
50' of fuel / coolant hose
wires and connectors
etc....
- Schwa
- Vehicle: 1992 Delica Exceed
the key thing to learn from the WVO horror story is that the guy who wrecked his engine didn't do ANY de-watering to his waste oil... so make sure there's no water and otherwise well filtered and you shouldn't have that kind of problem.
- sean
- Vehicle: WVO '91 Super Exceed
Hi David,
I live in Courtenay and have just finished my conversion (well, almost).
Check out my post. http://www.delica.ca/forum/deep-fried-t ... -1245.html
Love to show you the setup and give you any advice so that you will avoid mistakes I made.
Give me a PM if you want and we can exchange phone numbers and get together.
Sean
Sean
"I find television very educating. Every time somebody turns on the set,I go into the other room and read a book."
Groucho Marx
Groucho Marx
