-I just installed a touch screen PC, I should check the battery fluid levels.
-Battery is fine, but why does my radiator reservoir have a brown stain in it?
-That's because the head gasket is failing, I'd better fit a new one.
-The head has cracks in it, I'd better get a new head.
-While the head is off, I'd better rebuild the injector pump.
-While the injector pump is off, I'd better rebuild the air conditioning compressor.
-Since I'm rebuilding the compressor, I should fit all new O-rings and convert to r134a gas.
-To get to some of the O-rings I need to remove the front bumper and bull bar.
-Since the bumper and bull bar are off, I'd better get them powder coated!
See, logical.
More pictures here:
https://picasaweb.google.com/1171804076 ... directlink
And the pretty new cylinder head is here:
