What's this part?? I broke it.
flyaway
Vehicle: 1992 Delica
Post by flyaway »
Hello!
While installing a WVO conversion kit (yeah! nearly there!), I accidentally broke a part :shock: that now needs to be replaced (see pics). It seems to be some sort of a sensor (got wiring attached). Anybody knows what it is, where to get a new one etc etc??? Help is highly appreciated. The van runs without it, but I assume I should fix it anyway.
Cheers from Banff,
Miriam
This round plastic thingy broke where it's attached to the hose
what is it???
what is it???
general position (middle right)
legionnair
Vehicle: delica L300
Re: What's this part?? I broke it.
Post by legionnair »
Looks like a windshield washer pump, but not 100% sure
Rising Sun Auto Import
Not sure you are talking about this.
A/C vacuum solenoid?
http://www.delica.ca/forum/timing-belt- ... -9462.html
Steven
flyaway
Post by flyaway »
steven, you're right, it's the AC vacuum solenoid. Since I never use the AC (I always have it on "OFF"), does that mean that I can just leave it as is? And leave it to the next owner to fix it if there ever is a next owner that wants AC? or will something get destroyed that way? I read that post (link you put there), and that person bypassed it, but I wonder what that means?
rezdiver
Vehicle: 1991 L300
Post by rezdiver »
whats that block you are holding in your hand in the third picture?
Reza
1991 Delica L300
http://www.iltisforum.com/
flyaway
Post by flyaway »
:-) the supply valve. as i wrote, wvo conversion is happening.
rezdiver
Vehicle: 1991 L300
Post by rezdiver »
do you have a better picture of it?
Reza
1991 Delica L300
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
Not using AC won't affect anything but depending where the valve broke you could have a vacuum leak. When I took my AC out I plugged that hose.
flyaway wrote:Hello!
Cheers from Banff,
Miriam
Pull the vacuum lines and plug them with a bolt/similar.
Happy wvo conversion :M
flyaway
Post by flyaway »
Will do that (plug the vacuum line holes). Thanks a lot for the help everyone!
... and about the valve: I can post some pics once the conversion is done, or to just look at the valve: http://www.frybrid.com/parts.htm#valve
I think it's the regular one.
...and if you *do* decide to use your A/C, all that will happen is the engine idle speed will probably decrease a fraction when the compressor kicks in. It's no big deal.
