Panel/trim clips for rear door
- lettereleven
- Vehicle: L400 Super Exceed
Hi there
I wondered of anyone knew of a good place to get rear door panel clips. I've seen a few on eBay but if anyone has personal experience, I am eager to hear it.
I am also looking for driver /pass door panel clips, but not with the same urgency.
Thanks very much
Jamie
Thanks very much
Jamie
- MardyDelica
Re: Panel/trim clips for rear door
you can buy those thru local fastener store or any body shop supplier near your place
not hard to find just bring sample an dyou can find it
cheers;
cheers;
aclarker
Hard to find in Calgary, I ordered clips from cc auto. Napa has clips, although none fit...
- lettereleven
Perfect thank you both. I will try shopping around with a sample in hand.
- DelicaMark
- Vehicle: L400
I had to get some of these for my rear door panel too. I'm sure I got some Christmas tree style clips from either CT or Lordco. Just make sure you get approximately the right size and they work better than the stock ones.
- MardyDelica
hi, guys,
dont look in to lordco, or napa they dont have it try them they say they dont have.
go to the auto fastener store where they sell plastic clip for the body shop.
if you guys need it maybe i can buy it for you guys if you getting hard time to get this as i have good resource
for this clip dealing with body shop store.
just send me thesample pictures and will try the availability for you guys
cheers;
mardy
cheers;
mardy
- lettereleven
For those using "Search" to find panel/trim clip information -
After searching through about 100 different clips, I found these clips at Lordco that work really well.
Best part is that they are really easy to identify. They are the only ones that are bright yellow!
They are Ford clips, (i think 1/8" diameter). Sorry I dont have the SKU number.
- DelicaMark
- Vehicle: L400
Those are exactly what I used and I still think they are better than the stock ones...sorry Mardy.
- MardyDelica
no problem,
i am glad you guys find away to get this cheers;
mardy
mardy
- lettereleven
Here is the part number.
Apparently they are out of stock though. Arg, as I need a bunch more.
- ImageUploadedByTapatalk1333757853.450421.jpg (83.3 KiB) Viewed 6588 times
