Wanted slide door extension hinges
Shogopaintball1
- Vehicle: L300
Looking for door extension hinges or blue prints to make can any one help me out
Re: Wanted slide door extension hinges
I posted the dimensions/diagrams
If you search they will come
Noel at enviroimports made some too
Shogopaintball1
- Vehicle: L300
I only found one part if you can email me atrck_sauve@yahoo.ca
That would be great. Thanks for your help. Rick
Here you go. This is everything I have from Bruce and Noel.
- Hinge 001.jpg (47.41 KiB) Viewed 7093 times
- Hinge 002.jpg (58.02 KiB) Viewed 7093 times
- Hinge 003.jpg (40.51 KiB) Viewed 7093 times
- Hinge 004.jpg (42.96 KiB) Viewed 7093 times
- Hinge 005.jpg (40.66 KiB) Viewed 7093 times
- Hinge 006.jpg (37.36 KiB) Viewed 7093 times
- Hinge 007.jpg (32.25 KiB) Viewed 7093 times
cont..
- Hinge 008.jpg (32.53 KiB) Viewed 7092 times
- Hinge 009.jpg (41.99 KiB) Viewed 7092 times
- Hinge 010.jpg (41.76 KiB) Viewed 7092 times
- Hinge 011.jpg (49.04 KiB) Viewed 7092 times
- Hinge 012.jpg (74.09 KiB) Viewed 7092 times
- Hinge 013.jpg (51.41 KiB) Viewed 7092 times
- Hinge 014.jpg (54.18 KiB) Viewed 7092 times
cont..
- Hinge a001.jpg (32.37 KiB) Viewed 7092 times
- Hinge a002.jpg (28.6 KiB) Viewed 7092 times
- Hinge a003.jpg (32.19 KiB) Viewed 7092 times
- Hinge a004.jpg (29.39 KiB) Viewed 7092 times
- Hinge a005.jpg (28.38 KiB) Viewed 7092 times
- Hinge a006.jpg (26.42 KiB) Viewed 7092 times
- Hinge a007.jpg (27.66 KiB) Viewed 7092 times
cont..
- Hinge a008.jpg (32.99 KiB) Viewed 7092 times
- Hinge a009.jpg (27.92 KiB) Viewed 7092 times
- Hinge a010.jpg (26.78 KiB) Viewed 7092 times
- Hinge a011.jpg (29.24 KiB) Viewed 7092 times
- Hinge a012.jpg (29.17 KiB) Viewed 7092 times
- Hinge a013.jpg (26.36 KiB) Viewed 7092 times
cont..
- Hinge Dim1.jpg (46.75 KiB) Viewed 7086 times
- Hinge Dim2.jpg (68.38 KiB) Viewed 7086 times
- Hinge Dim3.jpg (25.05 KiB) Viewed 7086 times
- Hinge Pt1.jpg (26.9 KiB) Viewed 7086 times
- Hinge Pt2.jpg (33.32 KiB) Viewed 7086 times
- Hinge Pt3.jpg (12 KiB) Viewed 7086 times
Shogopaintball1
- Vehicle: L300
Shogopaintball1
- Vehicle: L300
Thanks I will start milling them up tomorrow
quite a few people ask for them often. if you are on the lathe/mill and make up more than one set, there's demand out there
Shogopaintball1
- Vehicle: L300
Yes I an an mill up a few more if I can get the specks for the spacer I'll Make them also.
Also might make spacer for the body lift too.
So if any one wants them just let me know and I'll price them out. Thank you
That was very helpful, thank you!
- Super Exceeded
- Vehicle: 1993 L300S
That would have been a lot easier than what I ended up doing......
I remember you saying "don't tell the wife" when I informed you of this option.Super Exceeded wrote:That would have been a lot easier than what I ended up doing......
