L400 super exceed Sunroof is f'd need help please
vanermi
Vehicle: Delica L400 Space Gear SE
Post by vanermi »
So im on the baja down in Cabo a d today my sunroof got jammed out of nowhere. While unjamming it the metal clip on the left side broke in two not to mention there is a broken plastic piece on the drivers side too. I'll try to post pics when at computer but need to hear from someone that is very familiar with these sunroofs and where I might get parts from as my brother arrives next week so can bring parts with him.
Thanks in advance!
Re: L400 super exceed Sunroof is f'd need help please
front of rear ?
If it's the front, you can manually remove the entire sunroof frame and work on it outside of the vehicle. By a long shot, this is the most convenient and simple way to work on it. Trust me. I've done it twice.
Once you have the worm gear moving, you can open/close it manually as well in an emergency if needed.
See here: http://www.delica.ca/forum/l400-front-s ... -8063.html
MardyDelica
Post by MardyDelica »
hi, you just need to open the middle light cover, with rear view mirror on it.
after than you cna see a nut with allen screw on it.
un screw it manuallly then the sunroof will move then close.
this will be simple.
did fix many of this. will works for you on this. try this your be ok
cheers;
mardy
vanermi
Post by vanermi »
Thanks guys, I have parts broken though and need replacements if possible. I have the roof closed but everything is out of whack now. The left side slide is in the closed position and the right in the open position and I have no idea how it got like that, but would have happened when I was trying desperately to open/close the roof.
Here are some pictures of the damaged parts. The black piece in my hand is from the drivers side.
