Cheers!
EGR Plates
- dennis_lambert
EGR Plates
I know this is a not the greatest Sketch.....But here is a pattern for EGR blanking plates.
Cheers!
Cheers!
- egr blanking plate.pdf
- (33.74 KiB) Downloaded 622 times
Re: EGR Plates
You got that right. Nice use of the 1 to 1 scale.
Did you make yours out of 1/4" plate?
- dennis_lambert
Re: EGR Plates
It was Drawn on a napkin sitting on a Stump,with pale ale in one hand...Windy day,raining ...up hills...
I will work on a better Drawing to replace the knapkin sketch while I am stuck in the office under soul sucking flourecent lighting and no windows..
Oh yeah ...The first plates I made were made out of 1/4 normalized plate steel.The next batch (if I ever get around to it) is the same,with the exception of the plate on the cold side, its will be now made from 1/4 thick Alum.
Re: EGR Plates
I think that's a good idea. I originally used a mild steel plate between the EGR and the intake. One day I was climbing out of Kamloops toward Merritt and I noticed a significant lose in power. When I got back to Van I opened everything up and the bolts holding the EGR onto the intake just slid out with the threads from the receptacle still wrapped around them. I had read about galvanic reaction but I never thought that it would really happen to me. In the end I had a quarter inch plate of aluminium welded over the EGR mount on the intake.dennis_lambert wrote:It was Drawn on a napkin sitting on a Stump,with pale ale in one hand...Windy day,raining ...up hills...
- dennis_lambert
Re: EGR Plates
Yes,Falco you hit the nail on the head!Dismilar metals corrosion
.Steel and Alum have different electrode potentials.The previous batch was however coated to prevent this...product improvment.Even a thin gasket between will substantially reduce the long term effect.
Cheers!
Cheers!
- Tojo
Re: EGR Plates
A PDF drawing based on your dimensions:
- EGR blanking plates_L300 and L400.PDF
- (73.46 KiB) Downloaded 753 times
Re: EGR Plates
There should be a gasket between the plate and the manifold, old or new. If the old one is baked on the EGR side and you can't remove it or is butchered, you can get exhaust gasket patch material at Lordco and cut it to fit = no problems. If the gasket is baked on the manifold side but still has material all around, that will work fine as well.dennis_lambert wrote:Even a thin gasket between will substantially reduce the long term effect.
Cheers!
- dennis_lambert
Re: EGR Plates
Thanks Tojo for the Awsome Drawing!!
Good point jfarsang on the Gasket!
Maybe a Moderator could move Tojo's Drawing to the tech section.....
