I am searching for winter rims/tires and wondering if Nissan Pathfinder rims would fit? I found a set that have a 6 bolt pattern and 235/75/R15 snow tires on them. Will that tire size work?
THank you very much for your advice.
Mark
Do Nissan Pathfinder Rims fit Pajero?
Re: Do Nissan Pathfinder Rims fit Pajero?
watch the hub diameter as they did not fit on my 1983 Toyota....
that tire size will work and bolt pattern is good
you just have to check the center hub bore
it should be 108mm
if it is smaller, it will not work or have to be bored out
it should be 108mm
- Firesong
Stock ones wont fit the delica on the front as they hit the control
arms (or whatever they are called) plus wont slide over the
hubs.
FS
hubs.
FS
- Vehicle: 1993 Pajero 2.8 LWB
Thanks a lot for the info, guys! I'm guessing it doesn't matter if the bore is bigger than 108mm, is that right? I think you have helped me find my new set of winter rims!
Thanks again,
Mark
Thanks again,
Mark
you also have to consider the backspacing (offset) and the width of the rim as firesong mentioned if the backspacing is too little, the tire/wheel may rub on the inner side.
you've got a Pajero in your sig so if that's the vehicle, common size is 7-8" wide wheel with 4-3.5" backspacking (7" wide and 4" backspacing is close to stock)
