__________________________________________________________________________________________________
Have to apologize about the pics. I had to toss 1/2 of them because they went all weird on me.
Here's the goodies.
I'm a fan of 'when I press on the brake pedal' my vehicle stops at a decent rate.
The stock single piston caliper's/pads the Delica's come with are 'o.k.' but my standards are somewhat high when it comes to braking.
Hence the upgrade. It's a direct bolt-on except two things :
1. shield has to be cut (top/bottom) about 2 inches to allow for the larger (longer) mounting bracket
2. brake line mounting plate onto the caliper is different. I just took it off. Doesn't make any difference.
As for the Superwinch manual hubs, I prefer manual hubs over auto's. I like to know that when it's off, it's off. When it's on, it's on. As well as manual hubs tend to be more reliable as there are fewer moving components internally and they are more robust. Downside is you have to get out of your vehicle to engage/disengage them.
Superwinch hubs from summitracing online in the US. $120 shipped
I bought all the brakes gear
-Raybestos Professional Grade calipers (semi-loaded = comes with slider pins,mounting brackets, pad mounting clips)
-Raybestos Professional Grade ceramic pads
-Raybestos PG Calipers
All are spec'd for a 1992 Mitsubishi Montero Sport (any parts place in US/Canada will have them)
Jesse
